Define "specs". Hardware with exactly the same port numbers? Uses the same 3G/4G frequencies? Same screen size? Same amount of RAM? If you want one identical you're not going to find one - even on the EVO Design 4G assembly line. If you want one with a particular spec the same, you're going to have to tell us which spec.
I don't know if this helps, but here are some with similar specs except ram (pretty close) and processor (dual core instead of single core).
HTC Droid Incredible 4G LTE - Fireball
HTC One S - ville
