Help Accuracy of S-Pen - Rather low?
twraia
Hi guys,
I've been using my galaxy note to do some casual sketching
I realised that the accuracy of the s-pen is not as impressive as I'd expected
For some reasons, instead of corresponding to the exact spot where the s-pen contacted the touch-screen, the writing always show up slightly above it.
This might not be a big problem for writing, but as far as sketching, it ruins the experience for me
I am wondering if any of you have encountered similar problems, or perhaps my galaxy is faulty to begin with?
thanks
the stylus is sensitive to a few things : angle you hold the stylus relative to the screen (it tends to favor 20-45 degrees) and the left/right hand option in settings.
It uses the gyros to determine some of it so don't put the note on a table and then rotate the note. it will get confused.
- Frank
Thanks Frank,
I tried different angles with the stylus, and found that I have relatively little problem aligning vertical lines with the contact point of the stylus, yet it remains horizontally challenged.
I still cannot align horizontal lines with the point of contact between the stylus and the screen
It will always be 1-2mm higher than the actual contact point
But I take it that this is considered normal?
frank ur right
i was also having de same problem as twraia but after i saw ur msg i tried it and now my s pen performs well and the fact that my pen didnt work properly because of the angle......... i tried changing the angle and my s pen works fine...i would ve gone to a service center if i wouldnt ve read ur msg.....thank u very much frank and u saved my money:):):)
