Advanced Explorer 1.1- The Best File Explorer For Android
pythonstw
10
1
Requirements: Android 2.2+
Overview: "Advanced Explorer 1.1!" - The simplest file explorer for android.
Quick access to all your files without folders.
Full functions with new and fresh design.
1tdzKacX3UXByqz-UvmMbOroG7bTuoaL72lnRr7ml-Ifs1XLkinRtDKfVDS5idJjEfJb=w705
Advanced Explorer gives you quick access to all your files:
No more wasting time searching in folders!
You will get all the relevant files in your memory card
(and external card) with one click only.
Advanced Explorer Features:
*Smart search engine.
*Maintenance: Delete broken files and empty folders from your device.
*Application Manager: Remove installed/unused apps,
backup and restore your important apps.
*Task Manager: Stop processes that are running in background
to save the battery life of your device/
*Themes management and more...
Free Version:
https://play.google.com/store/apps/details?id=com.advanced.explorer.python.lite
Full Version:
https://play.google.com/store/apps/details?id=com.advanced.explorer.python.pro
BEST TECH IN 2023
Smartphones
