depending on the phone you have you should be able to fo into settings and under wirless tab you should see airplane mode and then just uncheck it,or your phone could have the notification bar that you can pull down and uncheck it from there. hope this has fixed your issue,and if not you are more than welcome to create a account( free !!! ) and look up the type of phone you have and read up more on it.http://androidforums.com/
