Help Alarm is barely audible, Volume set High
FitzTML
So my alarm vibrate is louder than the actual audio of the alarm. I go to Settings >> Sound & notification >> Volumes. Everything is maxed out, when I adjust my alarm sound I hear it, loud and clear. When it goes off... It is very soft. What am I missing here?
I should mention that the countdown timer sound does not seem to be affected.
-Tim
AT&T HTC One M8
Android 5.0.2
You could try clearing cache/data for your alarm app and this will return the app to its defaults.Then set the alarm for a short time to see if that fixes the alarm sound.
With the latest update my alarm now rings low to start and increases every three cycles until it reaches its full intensity. Not ideal but not unacceptable. I'm sure there's an app to take care of it if it doesn't work for you. Might also try a different ringtone with an increased volume to start.
Cleared cache and data and still got the same thing :-(
Probably what today said that this is a "feature" Thanks!
