Root Anyhelp
hitmentip
Member
Okay So I have few Triumphs (3 maybe) And All of them have some kind of problem, one i broke the LCD screen, I would Love to fix it up but dont know how, I have another, I opened it up and f up the LCD screen as well as the camera..And on top of that, The speaks on top of the phone do not work, only works if you have headphone plug in. Also Now This phone will not boot up anymore.(So its save to say its useless lol) now i have another 1 But this one has a bad charging port.(yep u guess it)
Is there a video of some kind that shows me how to fix the LCD Screen...or the Charging port? On this phone...even a guide will do...Anyone Know Of ?
I found a couple of them that I used to replace a screen from a donor phone. Look up triumph screen replacement. You should be able to find a few videos on YouTube. You will need a small Torx screw driver, T7 I think. I got mine from Home Depot. It was a kit that has a bunch of bits with it.
