Root [AT&T] help with goomanager app
boogie85
Member
can any body tell me how goomanager app Works i need to change the rom of my one x evita i have twrp
any idea!!!!
I only use goomanager for flashing recoveries, stuff like goo and ROM Manager can be (or used to be, I've not used in a while) quite unreliable for flashing ROMs.
You're better off looking through the threads on xda/rootz/goo.im, downloading the zips and flashing manually. :)
You can flash the roms via recovery.
Generally how it's done...download the rom .zip file to your memory card.
boot into recovery, make a backup, wipe and flash the rom.
Now that is a very simplified version of how to flash a rom.
If you need the specifics, I can search around for ya, however, the sandman is calling me:) And I don't want to give bad info from being tired :p
No worries....another way to ask how to flash a rom is to start a new thread about it too:D
