Help ATT and VZW Note3 devices will not keep WiFi signal?
stanw
Aug 5, 2010
134
0
Recently, my Verizon Note3 and my wife's ATT Note3 are CONSTANTLY dropping our WiFi connection, making it almost unusable.
I tried my iPad and it seems to be fine, and so is my iMac via WiFi.
We rebooted the phones and it has not helped. This was not a problem before. Any idea why two separate Note3 devices from two different carriers might suddenly have a hard time keeping a WiFi connection?
Thanks.
Thanks.
These issues are almost always caused by your router/wireless access point, and it doesn't matter whether other devices work ok or not, because they've likely not tried to get an IP address from the router for days/weeks.
Reboot router, check for firmware update etc.
Change wifi channel, especially if it uses channel 6, the default on most routers.
Does wifi work at other locations? Another indicator.
  • Like
Reactions: stanw
Upvote 0
Thanks.
Per joshica over on the GS4 forum, try this:
Go into wifi settings and click on Menu, Advance Settings and uncheck the Auto Network Switch.
http://androidforums.com/samsung-galaxy-s4/810313-terrible-wifi-since-4-3-a.html#post6349321
Let us know if that helps.
  • Like
Reactions: stanw
Upvote 0
This helped somewhat, though the connectivity on both Note3 devices is still terrible, while I am able to use my iPad, Macbook Pro, and iMac and stream video to my AppleTV. It is very strange. I also just updated the Verizon Note3 with Verizon's new update, and that didn't seem to help. It all seemed to start around the time I received a notification that there was an update for the Verizon device, though I'm sure it is just a coincidence.
Upvote 0
BEST TECH IN 2023
Smartphones
