Basic custom themes :D
suhel28
this is a very basic guide to change colors and maybe icons if you've suitable icons
THINGS YOU'LL NEED :
  1. 7zip
  2. Any Imaging Software that can handle PNG files(I use PHOTOSHOP)
  3. FRAMEWORK-RES.APK file
STEPS :
  1. Right Click on your framework-res.apk
  2. Click 7-zip->Open Archive
  3. go to res folder
  4. Extract drawable-mdpi anywhere on your pc
  5. edit the files you want with your imaging software and save them
  6. now drag the modified files to the drawable-mdpi folder in the zip file
    Open the drawable-mdpi folder in your zip file
    select the modified files, hold and drag to the zip archive and leave it
    it will ask you to add the files or not
    just click yes
  7. Close the file
follow this TUTORIAL to push the file into your system
---------------------------END------------------------------------------
IMPORTANT TIPS
if you're upto modifying colors than you may notice that some files have extension .9.png they need special way to edit (actually not so special lol)
just open them in your imaging program
you'll notice few black dots and black border
something like this
keep those black things as they are, and mess around with the other colors
-----------------------------END QUOTE----------------------------------
for now I've just tested this with colors and few icons and it works
if anyone needs this framework (I changed the green color to orange, changed the lock symbol it was too small and colored some of the network indicators from white to green lol)
FRAMEWORK-RES.APK.7z
nice, looks good..
maybe later ill try it as i like the default color from se, so i juz set up my themes to make it suitable with defaultse ..
