Help Battery/Charger Problems
milee1000
Member
I have two problems. First my battery lose around 20% of juice from turning the phone off and back on. So is there a faster way to charge your phone? Also my phone doesn't correctly charge i plug in the charger and it says charging then it says please connect the charger. I think its because my charging port on my phone is loose. How can I fix that?
Thanks
There's no easy/quicker way to charge your battery. As for the loose charger port, it is time for you to get T-Mobile to exchange it if you have some sort of mobile "insurance" for your phone, as it is a hardware defect. Just make sure you flash back to the T-Mobile stock rom for the phone, as rooting it voids any sort of warranty and you'll be charged a non-refundable amount of $330 to your account.
Hmm... So i flash back to stock 1.5? But what can i do to reverse the root?
Im not really sure if this belongs in the rooting section of the forums or not.....
THANKS
