Battery Charging Animation (Boot) - How to change the battery animation
ajparag
3
0
I want to change the battery charging animation that lights up when the phone is charged while it is still switched-off. I have installed the "boot animation lite" to change the boot animation. however, it does not support the change of battery animation.
Can someone share the the path of the system file/folder which must be modded to change the animation?
I am using Spice MI 270. Its is a Chinese android phone (Model no. MT6516). One of the cheapest.
I will really appreciate your help. Thanks!
BEST TECH IN 2023
Smartphones
