BadSectorGR
Hi all,
I bought the Galaxy S4 Mini International Version Factory unlocked from Amazon. After charging and first boot I noticed that it has an O2 ROM most probably from Hungary, no issues with that so far (I think).
The problem is that after 2 full charge cycles, the battery is running low with the phone without used. If I leave it during the night at about 40%, in the morning I find it at turned off with battery on 0%.
Is it something that will go away as days go by or I should send it back?
I might install the official ROM before sending it back.
I have installed GSam Battery Monitor & Wakelock Detector and you can see my stats attached.
Thanks.
Thanks.
