Battery Use
jimbob35
Nope, this is not a moan about the battery charge.
Since the recent update my battery use monitor is acting strange, it reports over 90% use from android system, and the rest divided between wifi, BT and phone idle.
Now this has never been the case before, wifi and bt never went below 20%!
Yesterday the phone had been running for over 24 hours and it exhibited this issue, and today after 1 hour of battery use its doing the same.
The charge appears to last the same as before the recent update..
Any ideas??
Hello there,
I would advise you switch your phone off and turn it back on. Then view the stats.
I had a similar issue, it kept reporting Andriod System to use 95%. But then it dropped to 70%.
