Root Bionx 1.2.1 OPEN Beta [WIP]
Biotic
Android Expert
Bionx 1.2.1 Beta
~Building Intelligence was just the beginning...~
::Features::
=>Android 2.2.3 Framework (System)
::System is SUBJECT TO CHANGE UPON RELEASE::
-(WIP) Hybrid Blur Themed OS
-Honeycomb Clock Font
-HTC Themed Icons
-Droid Lockscreen
-One X Themed Fancy Widget
-Biotic Status Bar Icons
-ERI (Verizon LTE)
-Custom Ported APNS
-Droid Theory Init.D Scripting
-Over CLocked CPU
-Smart Processing
-Memory Savings
-Battery Savings
-Android ICS Based Settings
-Hotspot Integrated In Settings
-Integrated Go Launcher and Atire
-Bionx Wallpapers (Android Market)
-Phandroid Tapatalk, Amazon Marketplace, ICS music, Oi Files
-DSP with updated Audio Libs
-Transparent Custom Camera App
-Ads Blocked
-Bootanimation by Big DX
-Notifications Ported from HTC Devices
-Custom Notifications
-Droid Biotic Bootsound
=>Scripts
-Updated Bin Scripts
-Toolbox
-Modified Busybox
-Init.D Smart Scripts
-Task Killer
::User Scripts Can Be Found Via The Changelog Viewer Near Bottom::
::For A Full Changelog, View In Android Settings::
To Submit bugs/problems/concerns...Please post them here
Troubleshooting
General talk and Discussion here
To Begin your trial of Bionx 1.2.1
Build #3
6/10/12
::Download::
"Nightly Download"
Bionx 1.3
7/18/12
:confused:::WARNING:::confused:
If you intend on participating...Be SURE TO MAKE A NANDROID BACKUP before testing as a full system wipe IS REALLY NECESSARY. This ROM is still a WIP so, Some things may or may not work correctly and in order for those fixes to be made...I need your cooperation and android expertise to identify the bugs.
Before using the Beta, You must have flashed before hand Either Stormdroid, Velocity 1.0+, Bionx. Another words, your Ally needs the 2.2 Radio and Boot Image installed and rooted with preferably RA Recovery. If you are new to the Ally Root Section, Please ask before flashing and do your research.
::NOTE::This is a beta, Which means OS speeds can vary, Operation can vary, and performance may vary on devices. The default cpu speed is 600MHZ so, navigate to cpu settings in the Android settings to Adjust it. By community vote, the 360 Launcher has been replaced with Go Launcher EX with pre-installed Sense 4.0 Theme (Looks Good). Again, Follow Instructions, Do Not Distribute (only a link to this post is alright), and dont hate...Thats what twitter and facebook is for. Everyone knows what to expect as Ive kept everyone updated and Even listen to what the community wanted. Work will continue and more suggestions are being taken as this is my last firmware for the Ally.
p.s. "If a donation is to much, Pressing the Thanks button is just as generous;)"
I plan on testing this for sure. This evening, most likely.
By the way, do you mind if I ask why you skipped 1.1? Or was Update-1, released on 4/20/12, technically 1.1?
1.1 was kinda sorta Bionx Holo but i never got around to put things updated in the other builds. i kept on adding and adding and decided it was to much for just an update zip.
1.2 was my personal build
1.2.1 led to public release
P.S. I could not send Picture Messages to save my life. I even changed MMS.apk and SMS.apk around, still nothing. Reflashed several times.
Got another build coming soon.
-Script bug is fixed allowing busybox and su to work correctly.
- Rebuilding setup package
- Perfecting memory management (gained 40mb)
- Cpu governor update in progress
- Nx theme update
as far as the 3g icon, its stock from motorola (probably changing)
What about the MMS bug?
Also could not get 3G (MiFi) HotSpot to work properly. Kept dropping 3G signal/not picking up incoming 3G connection
im guessing my little access point mod to get better signal didnt work so il have to work on it.
"Also could not get 3G (MiFi) HotSpot to work properly. Kept dropping 3G signal/not picking up incoming 3G connection"
did anyone else have this problem?
New build should be up today
Build#3
=>I spent hours looking for MMS bug, I think i got it...Not sure
=>I redid the texting app so no more transparency, turned out another memory killer
=>As some of you can see of the preview, NX theme is updated and looken alot better
=>Gmail has been updated and modified so if an update comes in for Gmail, you cant recieve it but seeing that its perfect, why would you wanna update. The sync method is modded to be more precise and Widgets sync easier with this gmail package.
=>Memory tweaking
In order for some scripts to work successfully, its recommended to download script manager from google play. Some scripts are being tested, so some may or may not work to user expectation and if they dont, report them.
