Blocked call removal
  • Start date Start date
A
Android Question
Guest
Galaxy S Showcase has no access to blocked call list. I need to temove a call from the list that I accidently blocked.
Not sure if it is the same as my Galaxy S4 (4.2.2), but I will explain how it works on my phone.
  • Get the dial pad, the one you use to manually dial a number not in your contacts.
  • Press the menu button and select Call Setting
  • Select Call rejection
  • Now click on "Auto reject list"
  • Locate the number you want to remove, long press on it and from the popup menu select Delete, comfirm delete
If someone knows if it is the same on the OPs phone they can mark as solved.
