Root [Boost Mobile] [Android 4.3+] EASY ROOTING METHOD
Status
Not open for further replies.
Hello! So you want to root you'r zte n860 huh?
First, you want to download the clockworkmod easy root zip **mod removed link**
Second, boot into recovery by holding vol-up and power
Third, apply update from sd card and browse to EasyRootCWM.zip
Fourth, it should apply the update
Fifth, reboot normally
Sixth, you will have cwm recovery, SuperSU superuser app, and root acess
Hope this helped, if it did please click Thanks!
Status
