Root [Boost Mobile] Where to get Warp Original Media player apk
On the firewall I have an OC3 connection separated into 100meg pipes each of those pipes has a viada box and a barracuda box running in parallel. Each time I hit the link for the stockrom both alert to rogue scanners being detected, I also have an attack rep program running that verifies this issue.
On the video player apk what was the original name of the video player file as I do not see it in either of these zips. The video apk is there but that is not the stock apk that came with phone any help much appreciated.
  • Like
Reactions: LilBit
Upvote 0
This link is to a page right here. Dont know why your firewall went off.
http://androidforums.com/boost-mobi...t/521024-return-stock-cwm-updated-4-11-a.html
This rom may have the original video player.
http://androidforums.com/boost-mobi...enwarp-v1-0-4-update-released-11-18-12-a.html
Here is a rom guide, filled with lots of rom's to look through.
http://androidforums.com/boost-mobile-warp-all-things-root/570308-guide-rom-right-you.html
I can't remember the name of the stock player, maybe it was video player.apk? I have seen that in a few roms I looked in, most of the time a dev will replace it with a better one.
It should be inside one of the stock roms, You would think.
EDIT; This rom is supposed to be raw bone stock!!!
http://androidforums.com/boost-mobi...ot/609176-rom-zte-nexus-v2-available-now.html
Completely stock as far as apps go.
http://androidforums.com/boost-mobile-warp-all-things-root/675897-stock-b10-deodexed.html
  • Like
Reactions: laser48519
Upvote 0
LilBit the videoplayer.apk is a google video app it is not the stock player. I did load the alien rom and it has the original video player but I do not know what the file name is for the player he included there is no file named video anything in the alien rom zips.
Let me clarify on the rogue scanners, The link that sets off the firewalls to the scanning issue is not the link to the page but the link for this file: ZW-RTS-FOR-CWM-19-0B08C.zip
  • Like
Reactions: LilBit
Upvote 0
OK, This link is just a direct link to mediafire downloads where the file is stored, it should be safe.
If the stock player is avaiable its in a stock rom, and you can only get them as far as I know from someones dropbox account or mediafire, or wherever they have it stored.:D
Your firewall may go off, but I still think these sites we link to are safe. :)
Scan the file again after you download it to be sure. ;)
EDIT; I downloaded the BO8C and looked inside, I see a file called
mediaprovider.apk That may be it.
  • Like
Reactions: laser48519 and Doc
Upvote 0
here is my dilemma,
I am testing rtsp streams with the boost.
I rooted and left original rom running, I could use stock browser to call the rtsp feed and it would ask if i wanted to use movies or mx video player to play the feed(mx never worked for the feed) when I selected movie it would launch the stock player and work like a charm. Now I have tried several roms without the original player and even downloading third party apps the feeds never worked well. But when I use a rom with the original movie player the feeds are flawless and smooth. I was hoping to be able to install the original movie app to see if this resolves issues for me again.
Upvote 0
ok you can not ever install a system app what you do is get root browser or some file explore that you choose to use and move the apk from sd to system apps then change permission and restart phone
and i would not give up so easy you can find the og movie player just write mrbobo and he will help you nobody knows the noob rom like him he made it lol
  • Like
Reactions: LilBit
Upvote 0
BEST TECH IN 2023
Smartphones
