Root Boot into CWM.. help :)
pogue1000
Cool my first help thread, i been a reader mostly :)
I was goofing around on phone and now when it starts up i get a little icon of a phone a triangle sign and a computer icon.
Stupid me was going to put the new clockworkmod on there and the file was a zip file and i was going to use odin and it only accepted .tar so i changed filename... and it just sit there forever so i unplugged it.
How do i manually get into Clockworkmod recovery so i can flash it with the update.zip
Or best way to resolve this :)
I believe the new CWR.zip is flashable. You would just put it on your sd card and boot into CWR and flash it from there. Now if its stuck on that icon, I would pull the battery and then boot into CWR by holding vol up/down and power buttons. Someone chime in if I'm wrong here! But that is what I would do.
I had that issue on my friends sf. We had to re odin the dl09 all in one pack. I don't know if that's what you need to do, but that's how we fixed it. We couldn't get into cwr.
Ok i got into the CRM manual mode and hit apply update.zip and it just boots back to the same icon.
not sure whats up with that.
