Bricked Nexus 7 2012
Just found my old nexus 7 but it wont turn on, it shows up on my computer as an apx device but I cant get into bootloader and it isn't showing up as an adb device , anything else I can try??
thanks
Welcome to our AndroidForums, @razzman457 :).
I've moved your thread over here to the 1st gen N7 area for you.
First thing I'd try would be to make sure it's got a good, long, full charge on it (12 hours would be good) just to make sure the battery isn't drained.
As I wrote the above I realized you might have some charge on it since you're seeing something on your PC?
I'd still make sure you get a full charge first before expecting it to talk w/your PC.
Cheers!
Try pressing and holding the power button for a good 20 to 30 seconds. This should force a reboot in case something is locked up. (same as a battery pull).
Do you see any kind of screen flicker or image when you do this?
