Help Calendar Issues - "My Calendar"
jerksmile
Hey guys - I sure could use some advice:
When adding a new event in the phone calendar, it defaults to "My Calendar." This is new to me (wasn't on the moto droid) and apparently is phone-only, as it doesn't sync to my normal online google calendar.
Ideally, how do I just add new events directly to my usual google cal instead of this "My Calendar?"
Barring that, how can I get all new "My calendar" items to sync w my normal google login/calendar?
Sorry if it's a repeat question, this was the only relevant thread i found and it wasn't ever answered... http://androidforums.com/android-applications/8720-default-calendar-setting.html
Thank you in advance!
Have you added your Google calendar? I just fixed it on my Incredible. It's a setting that you have to dig for. Open the Calendar.
Menu > More
Calendars
Menu > Add Calendars
Select your calendars from the pop-up menu. They need to be calendars that are part of your Google account, but other than that, it works. I de-selected "My Calendar" and selected my others instead. When I add an event from the phone, it gives me a choice of which of my calendars to add it to.
