Help Can i lock my wallpaper?
Yeah you can't do that with Motorola's home or stock android home launchers.
Best bet is either Launcher Pro, like Readflea said, or ADW.Launcher, which I prefer.
If you use the moto blur widgets, not all of em work correctly on adw. You can resize the moto blur widgets but that's not supported in ADW, probably not LP either.
Hmmm...LP support resizable widgets (for all widgets) so it should/may(?) work w/the Blur widgets as well.
Upvote 0
BEST TECH IN 2023
Smartphones
