Help can't connect phone to pc help please!
justoneguy
Like the title says....apparently when i put it in any mode it installs everything except for mtp mode i think that's why i can't access my files in sd card...help please it's a pain having to take out my sd card and plug the card into the computer
When i connect the my phone to the comp i have to go back into connection mode make sure its in mtp then click home and once the sd card is done reading thats when it pops up in on the comp with all the files
Yes windows 7 to be exact so I am having trouble understanding why the problem exists since it's better then vista
How long have you waited for your files to come up? Once you plug in you phone to your computer, your phone starts the media scanner and won't display anything on your computer til its done. Also, are you running a legit copy with Windows Updates turned on?
Yes sir and yea I actually wait forever even after it's done scanning and nothing....i guess i just have bad luck and will have to deal with pulling the sd card out as usual
Did you ever have another LG device that you connected to your computer. I have this same issue. Every time I get a new phone (first my optimus, then my connect and now my motion), I have to COMPLETELY remove all my old drivers from the previous phone or the new one wont connect correctly. Just search LGs website for the newest drivers for this phone. Go into your control panel --> programs and features and uninstall anything with LG on it. Then reinstall the new drivers, connect phone when done, WAIT for windows to completely finish synching the device with the drivers, and you should be all good.
Yes i had an optimus and it worked just fine but the computer says I'm missing something on the computer and it won't connect the mtp but i had my hands tied lately...will continue to look for a solution
ok i tried updating drivers etc and this came up
"Windows found driver software but encountered an error while trying to install it.
LGE Android Net MTP Device
This operation requires an interactive window station."
