LG G2 phone 32gb unlocked (ATT) with custom rom loaded. It was a "modified" D802 rom (lolllipop) to run on D800. Lost root, so used AutoRec to try and root. Used D800 file to start and it told us to use D802. After ran with D802, it would only go into Fastboot mode. Thanks to a similar post, guidance by IowaBowTech got me to the point I am now.
(I did reflash D800 files when was in Fastboot Mode. Laf, Modem, recovery, boot, aboot)
Current state.
1. Can put in Factory Reset Mode and complete factory reset through holding Volume - and power button. Then goes to LG logo and stays put
2. Can go into Download Mode (Firmware Update) by holding volume + and plug into computer.
3. Can't find device under ADB or Fastboot
4. Stays at LG logo if just turn on normal.
5. Device Manager show Ports (COM & LPT)>LGE AndroidNet USB Serial Port
Tried
1. Finding device under Fastboot and ADB in both Windows 10 (can't find)and Ubuntu 14.04 (can't mount)
2. Tried loading Autoprime TOT files to put in original stock state using LGFlashTool with no success
a. Tried with D800 TOT files (actual phone Model) and said wrong model. Claims it's a D802
b. Tried with D802 TOT files (this also gave me an error)
3. Had Device Manager originally fixed and recognizing device. Now?????
4.Originally got drivers loaded via PDANET+. It Appears I have now lost that function too!
So to recap, "had" device manager recognizing device, LGFlashTool recognizing device but giving me a FAIL when trying to load D800 and D802. Now can't get Device Manager, LGFlash, ADB and Fastboot to recognize device.
Do I need to ReFlash Laf, Modem, recovery, boot, aboot files with D802?
Thanks in advance (sorry if I missed something)
UPDATE:
lgflashtool error codes;
D800 TOT file
Device model is different
Check phone or DLL
D802 TOT file
LAF Memory Error
Current state.
Tried
UPDATE:
D800 TOT file
Check phone or DLL
D802 TOT file
LAF Memory Error
