Help cell broadcast problem...plzzzzzzz heeelllllppppp
ratornado
hi guys, jst bought new spica with android 2.1...but i have a huge cell broadcast issue...i get approx. 100-200 sms from my service provider about my location n all...i know that this is a cell broadcast prob.....plz can anyone tell me whr r the cell broadcast settings in 2.1.....plz helpppppp
Do you mean APN settings?
Menu
Settings
Wireless & Networks
Mobile Networks
Access Point Names
Your Provider
@breeken- my service provider sends me info about my location(+ a small one line ad)......on my previous nokia phone it was displayed on my homescreen...but i thnk android 2.1 doesn't support such thngs from service provider...so it is created into a sms......
in all phones there is a choice of "cell broadcast on/off"...but i cudn't find in this phone....
plzzz help
hey breekan(sry for spellin mistake in my prev post)......i read it in your description that ur phone is rooted...can u plz tell me does rooting ur phone helps in anyway??.....and also does rooting ur phone makes ur warranty void???is it legal??
Installing a firmware not supported by your provider is most likely to void your warranty. While it is possible to revert back to your original firware, it's not very easy. I suggest mucking about with your phone for a few weeks to ensure it's all fully working. Then when you're happy update the firmware yourself. Chances are your phone wlll remain working, and on the updated firmware, long past the manufacturer's and your providers warranty. And all the time you benefit from the updates.
in the standard sms app, press menu, then select settings, scroll down until you get to "CB settings", and un tick "CB activation"
This will stop the "sms", your right, Nokia etc just dispaly it as location (ie: name of the cell site your attached to)
Cheers
Dylan
You can disable under SETTING-->Call-->Cell broadcast (uncheck)
Good Luck!.
