Root Changing roms again?
jackdsparker94
at the moment I'm running cyangenmod 7.1 and I was wondering about changing to another rom. If I use a nandroid back up on the rom I have atm will it be okay?
Thanks Jack :)
Do a nandroid backup, then basically you can just flash the new rom. If you don't like it, restore! :)
At least that's how I think it works.. it's what I've assumed when flashing stuff (never had a problem though).
Yeah me neither :P and I know how it works.
but was wondering is it different because it's a custom rom I guess not :')
Ima try a nightly soon :)
You running the CM7.1 RC1? That's just like a really old nightly (in terms of bugs and stuff), I'd switch to nightly 158 or whatever's out now.
I recently downloaded and flashed CM 7.1.0.1 onto my new Optimus 2x, after flashing, I cannot see my apps on Titanium backup, open Cynanogenmod settings (it force closes) and when i enter rom manager, it says i need to mount sd card (I've used my internal memory previously and now it can't be mounted?). I would really appreciate some help since the CM 7.1.0.1 rom looks really good and I don't want to flash back to a previous rom because i can't restore swype through titanium backup. Any suggestions?
You should probably post this here.
I guess you don't have an external SD card? Settings - CyanogenMod settings - Application - tick use internal storage.
