CM11 Developer and Tester thread for ZTE MSM 8x30 devices
I have created a CM11 / Kitkat compatible Kernel that should work with the following devices
ZTE Imperial N9101 (apollo) MSM8930 U.S. Cellular CDMA/LTE
ZTE Overture Z995 (becky) MSM8930 ATT\AIO GSM/LTE
ZTE Unico Z930L (coeus) MSM8930 Straight Talk GSM/LTE
ZTE Dave T83 (demeter) MSM8930 Telstra GSM/LTE
ZTE Source N9511 (hera) MSM8930 Cricket Wireless CDMA/LTE
ZTE Grand S Flex ???? (iris) MSM8930 GSM/LTE
ZTE Sonata / Radiant Z740 (metis) MSM8230 ATT GSM
ZTE Awe N800 (nex) MSM8630 Virgin Mobile CDMA
ZTE Blade Apex ???? (oceanus) MSM8930 ?? GSM/LTE
ZTE Max N5620 (stormer) MSM8930 Boost Mobile CDMA/LTE
ZTE Warp 4G N9510 (warplte) MSM8930 Boost Mobile CDMA/LTE
I have also created a CM11 device tree for the ZTE Radiant, and plan to make trees for the above mentioned devices.
This is still very early in the process, and rbheromax and myself have been trying to fix all the issues. rbheromax has been working with his ZTE Awe, and I have been working with the Radiant, we have received help from jetx2x, Dm47021, and others. METDeath has tested the kernel and ROM and found that it boots the ZTE Overture
But this is a lot of work and we need other people to join in and help out.
I have created a flash-able zip that can be installed on any of the above mentioned devices, the zip should detect which phone you have and flash the appropriate kernel and custom files for that phone
This ROM is not for end usage, there are a lot of things that do not work, it is only intended for people to be able to test and help us fix stuff.
It should be noted that it has only been tested on Radiant, Awe, and Overture so far.
A link to the flashable zip is below and should work with CWM and other recoveries.
Please note that it takes a while for the screen to come with this kernel/rom, so do not get scared, be patient, it should come in like 10 to 15 seconds after the first splash screen.
This zip will not copy the RIL (radio) files for CDMA devices, we need to find some RIL libs that will work with CDMA
ROM DOWNLOAD
https://www.mediafire.com/?a975urib6ldg79v
old roms
SOURCE CODE
https://github.com/hroark13/zte_msm8x30_cm11
If I have helped you, and you like my work, please click on the Thanks Button and give my thread a rating by clicking on the stars above.
If you would like to buy me a beer, you can click on the PayPal button
.hK
ROM DOWNLOAD
old roms
SOURCE CODE
.hK
