Help Contacts giving me headaches... help!
sulaco83
1
0
My contacts list works fine after a reboot for a day or two but then starts to get very sluggish to the point of being unusable. Pictures in dialer and contacts will disappear upon opening the list. Sometimes they come back and sometimes they don't. It gets slower and slower until it crashes and tells me "contacts has unexpectedly stopped working." If I reopen contacts after crashing everything works fine again. Clearing the cache does not help. Other apps perform at normal speed. I am on a RAZR maxx HD with JB and I did a factory reset after the update. All syncs are turned off except syncing to google. This is getting very annoying and any help would be appreciated!
Hi sulaco83...
Welcome aboard. Sorry to hear that you are having problems with your phone. Hopefully someone will chime in to assist you.
I've moved your thread to its area of support for further assistance. My suggestion to you is, do another reset and use the device as is without changing the default settings. Update all apps that need updating, and only install the ones that you really need.
Good luck. ;)
Upvote 0
BEST TECH IN 2023
Smartphones
