Help Create system profiles
bartjunited
I have a rooted s5 running stock rom
I have previously used the BlissPop rom and one really nice feature was the ability to create your own profiles, e.g work , home etc. and it would give you the ability to trigger these profiles by settings e.g when you connect to your home wi fi it goes to the home profile. This alos let you control what lock screens you enabled too.
Is it possible to do this on the S5 stock rom?
cheers Bart
cheers Bart
Have a look at Llama - Location Profiles and Map addon for Llama, free from the Play Store.
Thanks I'll look at this
Do you knwo if it's possible for it to disable the screen lock.
For work I have to encrypt my phone and therefore have to have a lock screen and pin. So I want to use this to keep the phone from locking when I don't want it do.. E.g I'm at home so don't need it to lock. In the car I don't want it to lock
Tried to use this to disable the screen lock for when I am at home or at work and can't get it to work consistently, driving me nuts
Go to Settings / Lock Screen and Security / Secure Lock Settings / Smart Lock.
You can set up your phone so that the lock screen is disabled when connected to certain bluetooth items (I have mine set up with my smartwatch), or by geolocation, or by your voice. No special software needed.
Thanks I have tried to set it to stay unlocked whilst I'm at home or work which I presume you need to keep the location service on for but it seems a bit hit and miss for me plus keeping the location on drains the battery???
