Credit card expiry date problem
gaugerer
Member
Dec 2, 2009
65
8
When I tried to buy an application from Android Market on my Pulse I was unable to enter my credit card expiry date because the format required was "MM/YY" and the number entry pad supplied by the software did not have a "/" character.
There was only a single box provided to enter the expiry date, so the "/" character was needed to separate the MM and YY data. No matter what I tried I kept getting an expiry date error.
I managed to overcome this problem by registering my credit card on Google so that the Pulse software did not ask for my credit card details when I buy from Android Market.
Has anyone else experienced this problem or know when there will be a fix?
Cheers Bill
Hi Bill
At first I assumed you didn't know about touch and slide down on X for the slash, but then I did what you did, and repeated the error. (BTW, if you touch and slide up it gives you a capital letter)
Seems to be a bug with the Touchpal software that is the default text input keyboard. I had a look, and had the same problem.
The option I got to work was to longpress the input field, and select input method, and then select the Android keyboard. That one has a slash selectable for input in the expiry date section.
Kind of annoying bug though. Registering with Google will make your next purchase quicker next time though?
And a quick search of Cootek's forums (who make TouchPal) shows no record of this bug/feature, so I might mosey on over later to report it.
Upvote 0
Hi Muuurgh, Thanks very much for your reply. When I was trying to enter my credit card expiry date, the software produced only a numeric keypad, so there were no letters to touch and slide.
I didn't try to longpress the expiry date input box to change the input keyboard as you suggest because I was unaware of that option.
Unfortunately, I cannot check to see if the longpress solution works for I no longer need to input my credit card data. However, others can try that solution if they experience the same problem and let us know if it works.
Cheers - Bill
Upvote 0
BEST TECH IN 2023
Smartphones
