wailord284
Hi guys, recently I tried to see if I could get CM12.1 to function on the ZTE Warp Sync. I used this CM (http://androidforums.com/threads/cm12-1-unofficial-rc5.919662/) and just changed the updater script from draconis to warp4. The phone so far totally works! The only problems I have encountered are:
Camera is upside down regardless of the app you use
LTE does not work and I cannot get proper APN settings to actually send or receive pictures. Sending and getting text messages works fine but pictures do not work. I tried fixing it with this (http://androidforums.com/threads/bo...al-boost-apn-fix-for-d2lte-builds-mod.840501/) but unfortunately that only fixed the problem for about 5 minutes.
Overall it works pretty well but I just can't seem to get APN settings to work for more than a few minutes.
If anyone has suggestions on how to fix this or has suggestions I'd be open for testing them.
Thanks for your support.![Smile :) :)](/styles/smilies/google/smilie.png)
