So im looking to get a data cable and a charging cable.
I didnt really want to just search for EVO data cable because then all that shows up is $10 cables, which i think is a bit much.
Is the connection a USB Micro B?
Does anyone have any recommendations (on Amazon would be preferable) for a data cable and for a charging only cable? From reading around it sounds like there are some cheap cables out there that dont cut it.
Thanks
Thanks
