vladguan
Hi All,
I have a problem with my Samsung Galaxy Nexus which started happening two weeks ago. The default browser times out on almost every website bar google.com.au when on home WiFi. Works fine on Work WiFi. Chrome on the other hand, has no issues.
I have installed WiFi Analyser and have set the channel on my D'Link DIR-835 to one that is not used by any surrounding routers. My wife's Galaxy S4 has no issues, nor does my ASUS laptop and wife's Dell laptop.
According to WiFi Analyser, the signal of the router is very strong, at least -65dBm. The next strongest is less than -90dBm.
I have googled and I found some posts with the same issue but no answers. Anyone know what I can change on my phone to get the default browser to work? It looks like a timeout issue as the blue line stops about 5mm across the screen.
TIA,
Vlad
TIA,
Vlad
