Default Task Manager: Posibally the answer to your battery woes.
dragma
The Task manager that comes with the Bionic may be a bit more powerful then you might expect.
Open it up it shows a list of the apps in memory, which like others you can shut down, the power comes from another feature that it has.
The Auto-end list.
This will shut down apps automatically 2 mins after the display times out. so you don't have to worry about them.
Pretty neat eh?
This will not take care of the power required by the radios, only for the power consumed by a hungry app that did not have the sense to shut down when you were done with it.
The Auto-end list.
Pretty neat eh?
Yup I use it and it works like it is supposed to work. Only thing I wished is this: apps> task manager> applications tab> menu> settings> System/core Applications. Put a check here and it lists the things I actually want to shut off (aka back up assistant!!)...but it won't and it can't. Oh well still a nice little feature from Moto :cool:
