I have my phone rooted back to the 2.2.1 now I need help flashing my phone. I cant seem to figure it out, any help would be appreciated thank you!
Now that you are rooted, you need a custom recovery to start flashing ROMs.
Now, you can do this one of two ways:
1. Fastboot
If you have fastboot (Download Quick Boot from the market, and tap bootloader. If you get a blue screen, you have fastboot), you can do this using that. You'll need to install the
LG USB Drivers, and download and extract
THIS zip. Then, open a command prompt in that extracted folder by holding shift and right clicking, and selecting "Open command window here. Then, when your phone is in fastboot, connect it to the computer, and type this into the command prompt
Code:
fastboot flash recovery recovery.img
That should send the recovery to your phone, and then once it says done, type
and you're done!
2. You can do it from ROM Manager
If you are already rooted, you can download the app ROM Manager from the Play Store [
Link] and do it this way:
Install the app, give it permissions, then flash Clockwork recovery
Then use the back arrow to back out of the app, until you return to the home screen. Then. go back into the app, and scroll all the way to the bottom, and flash alternate recovery. Do it multiple times to make sure it 'sticks'
BE ADVISED: If you reboot the stock ROM after doing this, you will have to re-flash the recovery, as the stock ROM has a script that overwrites custom recoveries on boot.
To do this, be sure to have a ROM on your SDcard, ready for flashing.
Power off your phone, and hold the SEND, MENU, and END buttons while powering up to ent4er recovery. You'll know when to let go when a menu pops up.
If recovery is < 3, use the keyboard arrows to select, and the keyboard enter key to enter. You will need to factory wipe, and wipe dalvik-cache, then, back out, and install from SD card the ROM you will have downloaded. Reboot, and enjoy.
ROMs you can choose from:
Velocity 1.2.2
StormDroid 2.0
Bionix
I recommend trying them all (PSST, StormDroid is best ROM
Hope this helps! (Hit 'Thanks'!)
