M
m4dj
Guest
Hi !
I cant find the way to disable keypress vibration on direct dial pad.
I have disabled the vibration on certain UI (haptic feedback) and also vibration on keypress (keyboard settings)...but on the direct dial pad when i press on numbers, the vibration is still present.
Anyone know if it is possible to disable also a vibration here ?
I have the latest android version from SE.
Thanks.
Thanks.
