Gekko
Android Expert
did you guys know about this? apparently on Gingerbread EVOs the setting is now hidden. here's how to find it -
if you want your unpaid apps to reinstall after the update you have to make sure the phone is setup to backup your data to google.
go to settings and hit the search button and search for privacy, click the only entry and check the box for backing up your data.
(thanks Brandito!)
(thanks Brandito!)
