My external SD Card is not mounting anymore. I have to manually mount it.
I am pretty sure in my case that it has something to do with the Internal SD Card. For some reason when the available space on the Internal SD Card reaches somewhere between 6.5 to 7 GB, the External SD Card starts having problems mounting.
I had my suspicions so I started completely new on this rom. The external SD Card worked fine...actually close to perfect as far as mounting, until the 7 to 6.5 GB mark. I noticed this on the other roms I tried too. The only thing I didnt do was go back to stock rom with everything factory. I am using Android Revolution 4.0 Rom.
I am S-ON. and I have 4ext installed.
Any help???
Thanks
Any help???
Thanks
