Root Flashing Desire S
someone57
2
0
Hi,
I have a desire s and I want to flash it with Virtuos Quatro ICS release. But, I can't use revolution io to turn s-off as the phone is HBOOT. So I was wondering what the best way to root it would be. Should I just use HTCDev and then flash or it is there an alternative.
Thanks,
@someone57
Only other alternate to HTCdev is downgrading your hboot. See here and here
By using HTCdev you are possible voiding your warranty.
If you do downgrade please just make a goldcard and before you do anything!!!!! Use mmc2 for the CID, please please please, some problems are easier to fix with it......
_____________________
Assuming you have hboot 2.00.0002
Upvote 0
BEST TECH IN 2023
Smartphones
