Root Flashing Process not working for Lollipop
gamea12
I'm trying to root my Note 3 SM - N900A using the instructions found here:http://androidxda.com/root-samsung-galaxy-note-3-sm-n900a
I'm on #9, which is to flash using Odin. The only problem is that this won't work. Here's the error code from Odin:
<ID:0/006> File analysis..
<ID:0/006> SetupConnection..
<ID:0/006> Initialzation..
<ID:0/006> Set PIT file..
<ID:0/006> DO NOT TURN OFF TARGET!!
<ID:0/006> Get PIT for mapping..
<ID:0/006> Firmware update start..
<ID:0/006> SingleDownload.
<ID:0/006> sbl1.mbn
<ID:0/006> NAND Write Start!!
<ID:0/006>
<ID:0/006>
<ID:0/006>
<OSM> All threads completed. (succeed 0 / failed 1)
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<OSM> All threads completed. (succeed 0 / failed 0)
<OSM> Please wait..
<OSM> Leave CS..
<ID:0/003> Added!!
<OSM> Please wait..
<OSM> Leave CS..
<ID:0/003> Odin v.3 engine (ID:3)..
<ID:0/003> One Click Downloader Mode
<ID:0/003> File analysis..
<ID:0/003> SetupConnection..
<ID:0/003>
And here's the error code from my phone:
UDC START
SW REV CHECK FAIL : [sbl1]Fused 2 > Binary 1
After this occurs, the download bar that shows on my phone stays stuck at around 5%, until I eventually have to turn it off. I would really appreciate it if anyone could help, and thanks in advance
