are you rooted? if so you can in fact tether. if your not I recommend you do. As long as you follow the guidelines when rooting you shouldn't have any problems. and once done all options are available.moving to kinda a country area i was thinking about purchasing a samsung galaxy from boost mobile doing the $3 a day plan unlimited 4g lte i was wondering could i tether the galaxy to say a pc or gaming console and use the 4g lte?
Probably not. Ask Boost about their tethering policy. (If they don't allow it, they block it.
Also, if you're going to br out in the sticks, make sure that Boost has a good signal out there. You may find that there's no signal at all. Covering 98% of the people doesn't mean covering 98% of the land. They cover cities, large towns, interstates and whatever signal leaks past those.
have fun.
p.s. if rooted they won't block you from tethering
