nickdalzell
Extreme Android User
KitKat was a non-issue for my Note 3, which surprised me. but given that it was not much on my Nexus devices i didn't expect much. absolutely hate the all-white icons though.
and, like my Nexus 7 and 10, no surprise, no ART. that's all that makes KitKat KitKat was ART. but without it's just a version number with nothing changed. of course, given that i hate change anyway, i don't care. i like my phone as-is. now if only i can get my green icons and other color up there back without root.
Verizon's version does not have the ability to disable the auto-check. it uses SDM.APK, one of Verizon's own apps, to replace the options in the Settings-->System Update menu. instead of the menu with the ability to turn off auto-check, it just produces a pop-up to check now. eventually if one is available you get a persistant notification and nag-screen for two weeks giving you the option to install now or postpone. eventually postpone is greyed out and it will update regardless unless you root and block the APK by removing it from /system/app.
