Hi everybody. My battery has been dying a lot quicker today . I opened up the battery usage , and it states Google services is using the most of it . how can I fix this ?. I appreciate the help.
Thank you,
Anthony.
Hi everybody.
Sorry I haven't replied sooner , but I was sick with a stomach virus . so I got gsam on my phone just today it spent 5:40 till 25% with 2:12 on screen time and 1:38 held awake . is that normal for this phone?. I'm really wishing for better battery life. Can't ask for everything though. I appreciate everyone's help.
Thank you ,
Anthony .
Hmm... That seems a little off, on a good day I get around 2.5-3 hours screen time over a full day (16 hours) and usually have 20% left, provided everything goes smooth with syncs and I have good signal strength most of the time. Now if I am getting poor signal or a sync has a hiccup, or use Maps much without connecting the charger it will not make it through the day usually.
If you have poor signal, the display brightness is above 30%, or an app is rouging out your numbers may be normal. GSAM can give you a lot more details though, go into app sucker and look at the app usage and time held awake by app.
Screenshots of the main screen and screen, radio, and app usage (set for time held awake) would be the most useful.Hi everybody , so alright I did some tests . nothing really seems out of ordinary screen usually about 20% or so , apps total at about 47% . android was the biggest being android at like 20 something or so % including Pandora and YouTube at about 3% each . doesn't sound horrible but I'm still getting about max 2:15 of screen on time . which y'all stated should be more . I'll attach a screen shot tomorrow . also does gsam have a history you can look at ?. I was hoping it did . I appreciate everyone's help,
Thank you,
Anthony.
The only thing that looks out of line here is mediaserver chowing the battery... you have a file that is causing the scan to fail... Mediaserver scans all files in your storage partition so that it can populate Gallery, Music, etc with the appropriate previews and info.Hi everybody I took some screenshots . I hope these will be helpful . somehow I find them a bit odd , but y'all know more than I do.
Thank you ,
Anthony .
