Google Voice but msg stuck on Verizon voicemail
nitrochris
7
0
I have my original Droid setup with Google Voice as the voicemail provider and it has been working great for the year or so I've used it. But I think somehow a friend managed to bypass my Google Voice inbox and leave a message on the carrier voicemail system (Verizon). So now I have a voicemail notification on the top of my phone that I can't clear and won't go away. When I dial *86 it goes to Google. I've tried to go under phone settings and change my voicemail provider back to carrier and redial *86 but it still routs to my Google Voice inbox.
Any Verizon or other users out there know how to check my carrier voicemail once google voice has been set up?
Thanks,
Chris
I get this notification periodically - usually I end up with a message with no sound... no idea how that's happening... to check / clear the message I just call my own mobile # from my cell phone and it lets me in to my verizon voicemail... see if that works rather than *86. If that doesn't work, try calling your GV number and then pressing option 2 to place a call and call your cell # from there - I think that has worked for me too...
Upvote 0
I managed to get it. Dialing my own number and calling my number from GV didn't work so I uninstalled GV and disassociated my phone from GV by dialing *73. Maybe I could have just disassociated it rather than uninstalling (I think the problem I was having was at the network level not on my phone). And it was actually a legitimate VM message so I'm not sure how it snuck through. Thanks
Upvote 0
FYI - you can use the "backdoor" number to get into Verizon's voicemail system and retrieve your messages. I think the number varies regionally, but there's a pattern to it - all the backdoor numbers end with 8686. For me, a backdoor number that works is 609-577-8686.
Once connected you can follow the prompts to "log in" to your own mailbox. From there you can listen to messages. You also have an option to send a message to another Verizon customer, which can be really useful if you want to leave them a message without the risk of having them answer the phone. This is at least one way that someone could have left you a message in your Verizon voicemail box.
  • Like
Reactions: nitrochris
Upvote 0
Just tried this and that number worked for me. Nice job!
Upvote 0
BEST TECH IN 2023
Smartphones
