Help gps and motorola atrix
sn0m
Hi gys
I bought a second hand motorola atrix 4g and running ice cream sandwitch in it. Everything works fine apart from GPS, don't seem to be able to log onto satellites. I have done dmesg | grep error but there's no error info about gps error. I have done a factory reset and also re-installed ICS but the faults persists. Does anybody know how to fix it, if not is there a command line that can be used to produce the gps error report so I can email it to the guy who I got the phone from.
Tnanks
sn0m
this is the output from dmesg | grep error
<4>[14669.301544,0] tegra-i2c tegra-i2c.0: I2c error status 0x00000008
<3>[14669.302705,0] lm3532_do_button_brtns_set: i2c_master_send error -121
<4>[14812.864935,0] tegra-i2c tegra-i2c.0: I2c error status 0x00000008
<3>[14812.866103,0] lm3532_do_button_brtns_set: i2c_master_send error -121
<4>[15042.230059,0] tegra-i2c tegra-i2c.0: I2c error status 0x00000008
<3>[15042.231608,0] lm3532_do_button_brtns_set: i2c_master_send error -121
<4>[15172.044712,0] tegra-i2c tegra-i2c.0: I2c error status 0x00000008
<3>[15172.046239,0] lm3532_do_button_brtns_set: i2c_master_send error -121
<4>[15469.790393,0] tegra-i2c tegra-i2c.0: I2c error status 0x00000008
<3>[15469.791915,0] lm3532_do_button_brtns_set: i2c_master_send error -121
<4>[15512.056535,0] tegra-i2c tegra-i2c.0: I2c error status 0x00000008
<3>[15512.057988,0] lm3532_do_button_brtns_set: i2c_master_send error -121
<4>[15515.619549,0] tegra-i2c tegra-i2c.0: I2c error status 0x00000008
<3>[15515.620608,0] lm3532_do_button_brtns_set: i2c_master_send error -121
<4>[15595.364946,0] tegra-i2c tegra-i2c.0: I2c error status 0x00000008
<3>[15595.366460,0] lm3532_do_button_brtns_set: i2c_master_send error -121
<4>[17791.144579,0] tegra-i2c tegra-i2c.0: I2c error status 0x00000008
<3>[17791.146190,1] lm3532_do_button_brtns_set: i2c_master_send error -121
<4>[18327.466883,0] tegra-i2c tegra-i2c.0: I2c error status 0x00000008
<3>[18327.468466,0] lm3532_do_button_brtns_set: i2c_master_send error -121
<4>[18463.381378,0] tegra-i2c tegra-i2c.0: I2c error status 0x00000008
<3>[18463.382902,0] lm3532_do_button_brtns_set: i2c_master_send error -121
<4>[19088.423042,0] tegra-i2c tegra-i2c.0: I2c error status 0x00000008
<3>[19088.424209,0] lm3532_do_button_brtns_set: i2c_master_send error -121
thanks for looking at it
sn0m
Moved your post here for proper support. Cheers ;)
