GPS Indicator Half On?
Hi all,
I'm sure this has been addressed plenty... my rooted N7 has had the control widget GPS indicator half on since the last update. I read that this is likely due to some app requiring use of the service but I'm not sure of the best way to find which one it is.
Suggestions?
Thanks!
To the best of my knowledge Half on is battery saving mode (network location on, GPS radio off) all off is GPS off network location off. All on is high accuracy mode (GPS on network location on) then theres device only which I think is all on also (GPS on only) hope this helps
