GPS on Droid. . .Is there a setting for ON/OFF?
I have searched for GPS on the forum, but didn't see anything come up, so I am posting a quick question.
I want to use Locale and the app says that it functions more accurately when GPS is enabled, but for the life of me I can't find where I turn that on or is it always on (default)?
The big reason I ask is that I set up a situation in Locale that was "Home weekend" and entered my home location, but the app does not seem to recognize my location and is in "default" situation.
Thanks all!
Thanks all!
for convenience - add the power widget that comes with the phone on your homescreen. There you can toggle many things, GPS included.
Upvote 0
Being that GPS tends to kill battery, I've found that under "Menu/Settings/Location & Security" check off "Use wireless networks" This will keep a general area of where you are just about whenever you have signal, and not KILL battery. Then just toggle GPS on/off as necessary to preserve battery.
EDIT: by "check off", I do mean have this box checked (avoiding confusion)
Upvote 0
Upvote 0
BEST TECH IN 2023
Smartphones
