Handcent problem: can't copy attachments to SD card
UNCbassbone
12
1
First off, I am running 2.1 from OTA update. I use Handcent and previously I had no problems copying attachments to my SD card. Now, however, I try to copy a photo from a MMS and I get the error message "copying attachment to SD card failed." Did I mess something up by accident? Are there any settings or anything I can check to make sure I didn't change something inadvertently?
Yep; been there, done that
http://androidforums.com/htc-droid-eris/81148-2-1-ota-sdcard-misery.html
uninstall/reinstall or as some say - full reset ( I didn't want to do that )
Upvote 0
BEST TECH IN 2023
Smartphones
