Root Hard reset via pc, need help :,(
CrimsonV
i got an xperia mini st15i, and i had the back/menu button sensitivity bug and i tried to fix it by running the following gsl script
Code:
dev=/sys/devices/platform/spi_qsd.0/spi0.0 fw=touch_smultron_sony.hex cyttsp_fwloader -dev $dev -fw /system/etc/firmware/$fw -verify_only sleep 5 reboot -p
http://dl.xda-developers.com/attach...342d38/4f4b6329/8/4/0/3/8/5/touchpanel.sh.txt
in GScript Lite, and after that my touchscreen stopped working :( including the menu and back button, so how could i fix this, can i do a hard reset via sdk or i dont know.
usb debuging is enabled and my phone is rooted, oh and PC Companion doesnt recognize my phone
You should always do a nandroid backup before changing anything system related.
I think backup is the most important thing to do, when you're "playing" with your phone. I usually do a nandroid backup every other day...
Try reseting it. If it doesn't work, you'll have to flash it... but before that backup all your sys&app settings with titanium backup or some other app you prefer.
