Help HELP captivate I897: How to undo JellyBean to GB 2.3.5
nmanee
Dear Experts,
I really need anyone of you to help me. I have Samsung Captivate I-897. It was updated from Eclair to GB. Then I used KK4 and UCKF1 to upgrade to GB 2.3.5. However, due to GPS problem (original problem of I897) was not fixed and I found the GPS_mod(8NTP) to fix the problem by flashing. But I have to flash it. So I need GingerBrake that build in CWM version then I was upgrade to CornKernel_UCKK4_v705.tar. Then I found upgrade to CM10 Jelly bean via Salty_Bean_25_10122012 and Salty_Bean_Addons_20120926. After successful upgrade. My GPS worked but not web browser. I don't like many feature of the jellybean. So I try to goback to GB 2.3.5 by using Odin3v1.85 to put the KK4 and UCKF1 back. Big mistake.....Phone will not reboot. It stucked on ATT sign the whole time until drain all my battery. SO NOW I AM STUCKED. NEED HELP. PLEASE HELP!!!!
I think during process of upgrade to CM10 I have to wipe out factory setting data. That is why the phone don't have any instruction to do. Please help. :confused:
Dear Experts,
I really need your help. I have Samsung Captivate I-897. It was updated from Eclair to GB. Then I used KK4 and UCKF1 to upgrade to GB 2.3.5. However, due to GPS problem (original problem of I897) was not fixed and I found the GPS_mod(8NTP) to fix the problem by flashing. But I have to flash it. So I need GingerBrake that build in CWM version then I was upgrade to CornKernel_UCKK4_v705.tar. Then I found upgrade to CM10 Jelly bean via Salty_Bean_25_10122012 and Salty_Bean_Addons_20120926. After successful upgrade. My GPS worked but not web browser. I don't like many feature of the jellybean. So I try to goback to GB 2.3.5 by using Odin3v1.85 to put the KK4 and UCKF1 back. Big mistake.....Phone will not reboot. It stucked on ATT sign the whole time until drain all my battery. SO NOW I AM STUCKED. NEED HELP. PLEASE HELP!!!!
