Help I don't know my tablets name
Jmejia051
So for some time now I've been trying to figure out what the name of my tablet is. I threw away the box so I don't what it is.
It's model number is :fj_vortex
It's android version is : 4.0.3
Kernel version is : 3.0.8
It's startup says vimicro. For a while I've been trying to figure out the name but I have no idea. I've seen very similar ones but I have not found an exact match. If anyone could help me please and thank you :)
Hi Jmejia051 and welcome to AF!
I believe that your tablet is a Vimicro FJ Vortex. What is the tablet screen size, a 7 inch or 10inch?
The model base on a lot of theses tablets seem to be a A8 - 882
You can also try and download the "Spec Device" app from the playstore and this will give you detailed information on your device -https://play.google.com/store/apps/details?id=com.specdevice
Hi, I think I have the same tablet, and desperately need some help in finding this tablet's User Manual, and also need to know which mico SD/TF card to buy for it. I really HOPE and pray someone out there can help me! I also am unsure of the kind of USB cable I need (this tablet was given to me without any accessories), but am going to go ahead and just buy a standard "6ft USB 2.0 Type A Male to Type A Male cable cord", after lots of research I've done and visually seeing the size of the slot. PLEASE HELP.......
Thank you VERY MUCH :confused: :)
Manufacturer: Unknown!!
